Classify a track as an audiobook...
15,385
1,089
...is there any way to do this manually? I can't seem to find the option...
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
Ok, I found something that should do the trick. It's very similar to the ringtone workaround for iTunes.
Select the Audiotrack that you have that is mp3. Convert the selection to AAC. Once it is converted to AAC, delete the original mp3 file and view the new AAC track in Finder. Select get info and then change the file extension from .m4a to .m4b. Then you simply add the new track.m4b file to your library and it should show up in the Audiobooks tab and sync to your iPod as an Audiobook file.
15,385
1,089
tedious, but it worked... Apple must know that people burn audiobook CDs to put on their ipods... why not allow us to classify them as such?
I guess they're trying to force us to purchase them from iTunes instead...
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
I agree completely. I got all 7 of the Harry Potter Audiobooks before I learned how to do this method and ended up just repurchasing them on iTunes. I'm sure they loved that.
Dec 7, 2008
Can't even get audiobook to become anything
:laugh2:Have worked over 4 hrs.trying to download an audiobook to iPhone 8Mg.
It is almost a joke. Went to Splasm.com and downloaded a introductory
software which claims to change format for iPhone. Audiobook Builder
can be a purchased software for $9.95. I jumped for the ten dollaris and still
can't figure out how it can work since I can't Open my audiobook from iTunes so I can open it in their dialog box for reformatting. Sorry I can't help you
anymore than this.
