Cleaning the laptop
silvermoon
Jul 17, 2013
1,624
179
Washington
I know that the best way to clean the glass or screen is with the microfiber cloth. Do you think it is a good idea to get the cloth damp? I'm hesitant to apply any water to the screen.
What about cleaning the keyboard? I was thinking of using a tube attachment with my vacuum cleaner on low power but I'm worried about electrical discharges. It would be nice to remove some of the particles that may have fallen under the keys without having to take apart the entire keyboard.
When I consulted with one of the reps at the Apple Store, he told me to bring it and let one of their certified technicians do the cleaning. I don't really think all that is necessary and I can handle it for the most part.
Any other suggestions that have worked well for you?
Dec 15, 2008
5,386
340
Pensacola, FL
I don't believe taking it to the Apple store or anywhere to get it cleaned is all necessary. For the screen I don't clean it often and when I do it's just with a dry cloth or my shirt lol. For my keyboard I have one of those rubber keyboard pieces of whatever that goes over it. I put that on there due to a medical issue I had where I then got sick on my keyboard and that caused other computer issues. Anywho, whenever I take that piece off, my keyboard looks brand new.
To be honest, I don't see cleaning the screen or the keyboard is 100% necessary, but that's just my opinion.
Mrallank59
Jan 8, 2013
250
31
This keyboard cover is great for keeping dust particles out of your laptop
Mrallank59
Jan 8, 2013
250
31
If you use your laptop as little as I use mine it should last indefinitely.
