Cleaning the screen
gurvy
Jun 20, 2007
45
Does anyone know if we can use any solutions to clean the screen. The Apple store is seeling a small spray bottle the looks a lot like what I use to clean my TV LCD screen. I remember reading that we should not be using any solutions. The cloth that they gave is just not doing a good job.
Any thoughts?
DRabbit
Jul 2, 2007
383
Any thoughts?
I'm using microfiber cloths I bought at a local automotive store (usually Kmart or Walmart has them too). When I bought an Apple Cinema it came with a free microfiber cloth that was REAL nice, and I keep that in my car now also. No solution needed... just a quick buff with a microfiber cloth does the trick :)
The problem with the one included is it is too small. You just need a bigger, thicker one.
gurvy
Jun 20, 2007
45
wjp09
Feb 25, 2007
2,559
25
NJ
I turn it off completely. Put the cloth on about 1/3 of the screen PRESS down and slide up, move over 1/3 repeat, and once again repeat.
mav
May 9, 2007
356
I used some screen cleaner from Monster. It's meant for LCD TV'sa nd monitors but works well on the iPhone. Just spray a bit onto a microfiber cloth and wipe it a couple of times. Make sure that you do not spray it on the iPhone directly.
gurvy
Jun 20, 2007
45
I have that same Monster spray...did u use the blue cloth that came with it or another microfiber cloth?
EJW2202
Jun 27, 2007
72
When I put it in my pocket the pocket material ends up taking off all of the finger prints, so i basically never clean the screen. If i were to though, then i just use the cloth it comes with.
spud2007
Jul 9, 2007
56
What is the best way to clean your screen without using the soft cloth that was provided?
cdoyle
Jul 9, 2007
46
I find taking a little paper towel and folding it into a small square and putting a little bit of window cleaner on it like windex..not too much lol don't wana ruin the phone just engough. This cleans the screen up and makes it look and feel like it just came right out of the box.
cdoyle
Jul 9, 2007
46
lol, well ive been using it for the past 2 weeks and it seems fine, doesn't seem to do anything bad to it? do you know where you head that?
spud2007
Jul 9, 2007
56
iPhone user guide/manual page 108, yes i agree i thought a nice microfiber cloth would do well.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
I use the little square wipe that came with my RAZR sometimes, but mostly use the microfiber Oakley bag that came with my sunglasses when I'm in the car.
spud2007
Jul 9, 2007
56
haha thats exactly how I am. The oakley bag. I cant ever seem to get my screen grease, streak free though.
