cleaning up after 1.1.2 update
Aug 10, 2007
11
I recently updated my already jailbroken 1.1.1 to 1.1.2. I had a lot of stuff installed. After the update, all of the programs I had disappeared. I know they are still on the phone as i have seen them with mobile finder. I wanna clean those files up. I wanna get rid of them and basically start over. What should i do?
x999x
Aug 6, 2007
1,656
I found that my old symlinked apps were shuffled around into one of the USR directories if I'm not mistaken. I sniffed around and found them using Cyberduck over an ssh connection. I backed them up, just in case, and then deleted them followed by a soft reset. Hopped back into the phone and everything ran smoothly.
My Old Apps folder was 28 megs, not much, so whether or not you can find the old apps folder you're not going to be recovering a huge amount of space.
termleech
Sep 7, 2007
1,154
McPherson, KS
The easiest way is to reinstall them, then uninstall them. Otherwise you can just delete them out of the /Applications directory.
