Clear Skins Full Body Protection
Dec 15, 2008
5,386
340
27
Pensacola, FL
Are you referring to the invisible shield full body protectors? I do not believe they are permanent. Nothing is truly permanent in this situation. They are not bad, but they are definitely expensive.
In my honest opinion, I do not prefer protectors that you must put on yourself. You can have them put it on for you, but it does take a little while to get all of the bubbles out, and even then a day or two later a small bubble or two or three may appear. I prefer a full body case such as the otterbox. Yes it's somewhat bulky, but all I want is protection. I don't mind the bulkiness.
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
I've used both and have a preference for Invisible Shield. Both are easily removed and won't leave any permanent residue. They will do a great job at protecting against scratches.
