Clearing outgoing/incoming calls
DHTPHTG34
Dec 30, 2007
Is there any way to just clear a few of the calls? Whenever you clear recents it clears all the calls.
thanks,
KNK
Jul 22, 2007
2,391
Stevenson Ranch
thanks,
It will clear ALL or MISSED only.
They drop off after a certain time, mine goes back to Dec 14 as the oldest, so its about 4 weeks.
DHTPHTG34
Dec 30, 2007
On mine, it does not matter if you have it under all or missed, if you hit clear it clears them all. Seems odd, you should be able to just clear a few or all of one set either all or missed. Maybe in the future update.
thanks,
KNK
Jul 22, 2007
2,391
Stevenson Ranch
thanks,
Yeah you can't do the edit to delete yet.:)
guest0320
Nov 11, 2007
728
Sorry, can't help you then.
I use WeTool (on a jailbroken phone) for exactly what you described.
Dana
