Clock Timer on lock screen?
alexuk
Nov 27, 2008
Is there an app out there (or any devs feel like making one?) that will show the countdown timer (from 'Clock') on the lock screen when it's active? Similar to how Lock Widgets works, just a small font with the countdown.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
Good question...No is the ultimate answer here. However, I do believe there are apps you can pay for or free through Cydia that are timers only...With that you caould also install the "run background tasks/apps" application found in Cydia and set your phone's settings to never lock and you should be fine....Maybe just using the settings for your lockscreen might work...Good luck
