Closing background apps on iPad 2
Lorofio
Jan 19, 2013
I bought my iPad2 in April 2012. Recently I've been having problems with the Home button behaving erratically. I'm unable to double click to reveal background apps so that they can be closed. I've tried holding both buttons until the silver Apple appears but this doesn't help. Is there another way to close background apps. All help appreciated.
Sent using iCafe app
talon90
Jan 17, 2009
290
29
As I'm sure you are aware, double tapping the home button is the primary way to get to background apps to close them. If you also have screen gestures turned on you can use four or five fingers on the screen and swipe up. This will also expose the tray so you can switch to or close background apps.
Lorofio
Jan 19, 2013
Gestures is on - it doesn't like swiping up - I've tried in both landscape and portrait - and - in desperation with wifi and Bluetooth off. Thanks for your quick reply.
talon90
Jan 17, 2009
290
29
Not sure why. It works perfectly with mine. What iOS version are you using?
Lorofio
Jan 19, 2013
Yay! Recalibrating the home button worked - I managed it with contacts app open - many thanks for all your help.
All you need to do is reboot. Rebooting daily will help keep it running optimally. It closes all the apps. They will still be in the task switcher so they are available for quickly switching between apps, but they are no longer in a running/frozen state.
It's a misconception that the steps in the video will actually calibrate the home button. All it really does is force quits apps.
Lorofio
Jan 19, 2013
Thanks - will reboot regularly - hopefully it'll prevent the home button freezing again.
RoofMonkey
Jun 21, 2010
8,924
1,983
In the original post they said that they had done a hard reboot and it did not work.
So it seems doing something in that video worked, or it's a fluke ;)
It was a fluke. It really doesn't do anything other than force quit apps. I used to believe it actually calibrated it until I researched it pretty extensively a year or so ago. Apple never published anything about it aside from its official function, which is force quitting apps. Still, it does seem to have a placebo effect sometimes.
Lorofio
Jan 19, 2013
Yes, I recalibrated as shown in the link - it seems to have worked as I could use the Home button again, double clicked to reveal the background apps and closed them all normally. I'll get into the habit of clearing daily and re opting more often. I've a tendency to leave it on 24/7.
Lorofio
Jan 19, 2013
Something did the trick - not had any problems recently - thanks for your help :)
