clueless...
ladybuggy
Jan 4, 2008
14
I used the installer and I finally have a lot of stuff but for some weird reason the installer icon disappeared and I don't know where it is. I didn't know you can only put so much on the home screen. I didn't know that you can't scroll down and if you reached 16 applications it will start hiding some of them. I'm so clueless and technologically stupid. help?!
bry279
Apr 3, 2008
Its ok - I'm that way too!
Quick question...
How many little dots on your screen right above the dock?
For Example..
This is my "main screen" ..but if i slide it to the right ...
I get page two.
The dots tell you which 'page' you are on
Hope it helps
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
It probably just moved it to the second page. Try flicking the page to the left just like you do when you scroll through your different weather locations.
ladybuggy
Jan 4, 2008
14
For some reason, it doesn't work.
It doesn't have 2 dots at the top or bottom of the page.
I still don't know what to do! Please help!
Is there another way to look for it?
adseguy
401
What version of the iPhone firmware are you running? You must be on at least 1.1.2
You can find this when you sync the iPhone in iTunes on the summary page.
ladybuggy
Jan 4, 2008
14
yes i have the 1.1.2... do you mean i would find the installer icon thingy when i sync it to iTunes or i would find what kind of firmware i'm using?
