Combining 2 iPhones into one...
Misie
Jun 14, 2010
143
45
Louisiana
My question is. My son had an iPhone which started giving problem like when plugged to an outlet it would show 100 charged but saying to plug into iTunes. And when plugged in computer the Apple logo would just come on then turn off continuous cycle with iTunes never recognizing it. Well we bought him a new one and he shattered the front glass. So he decided to try and change the front glass and was much trouble. So he just switched the batteries and the old one works now. So just a battery problem. But now he would like to merge the both phones to one. Might there be an easy way to do this?
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Merge as in contact, apps etc...?
If he previously backed everything up on iTunes there shouldn't be a problem at all and as simple as syncing everything on the phone is using now.
