confused about what method to mod, please advise
DoubleD
Aug 31, 2007
68
New Orleans
Hi guys there seems to be way too many guides/apps for our own good, I realise things are changing daily but I'm still confused so if anyone would please give me some advice on what programs to use for what I want to do would be greatly appreciated.
What I want to do:
Change Home screen backgroud
Change the home screen icons
Change the dock
Add my own ringtones
What I'm running:
Windows XP
iPhone Firmware Version 1.0.2(1C28)
iTunes 7.4.0.28
TIA!
unknownentry
Jul 19, 2007
204
Knoxville, TN
www.iphonesurge.com
What I want to do:
Change the dock
What I'm running:
Windows XP
iTunes 7.4.0.28
TIA!
iBrickr can be downloaded here.
My iBrickr guide can be downloaded here.
(My guide lists where to put everything including ringtones & wallpapers - It also has a list of recommended applications that I personally use)
Let me know if you need any help!
:laugh2::laugh2::laugh2::laugh2::laugh2::laugh2:
DoubleD
Aug 31, 2007
68
New Orleans
Many thanks for the help offer, I'm sure I'll need it!
I see Nate's site still says ""Free my phone" is currently broken in iBrickr v0.8 with iTunes 7.4, unless you have a copy of the older iTunesMobileDevice.dll in the iBrickr directory. A fix is coming soon. " so will iBrickr not work with me running iTunes 7.4?
venturo
Sep 9, 2007
30
Download this
http://rapidshare.com/files/55269765...pInstaller.exe
double click file
follow directions
close iTunes and plug in iPhone
This will jailbreak your phone for further modding, the installe comes with a variety of things to add, pretty much a one stop shop, after this you can get ibrickr and start to mod files like yur png and caf files. once the installer is done, you will end up with a icon labeld installer, when you go in it there will be a ton of things. for wht you want to do, i'd install "community Sources" and "summerboard".
unknownentry
Jul 19, 2007
204
Knoxville, TN
www.iphonesurge.com
It works for me so I don't know how accurate that is. Nate doesn't update things much. He is too busy making programs and other things.
DoubleD
Aug 31, 2007
68
New Orleans
I just don't want to get stuck in the endless loop syndrome and from what I've read the 7.4/1.0.2/iBrickr 0.8 seems to be what causes this
Whats the fix for the endless loop if I get stuck in it
Jul 10, 2007
84
Jan 11, 2007
101
Cary, NC
I tried to install AppTap and it said it was going to take 20 minutes or so to install. I thought surely this isn't correct so stopped it. This entire Mod thing is not for the weak at heart IMO. I think I'm going to just hold off and be happy with what comes on my iPhone.
Aug 9, 2007
178
I finally jumped in (slightly)
The only thing I've done before today was add ringtones using iPhoneringtonemaker (Awesome application). I had considered installing iBrickr before all the updates started rolling out, but decided to wait. I read a post on this board about the new version of Apptap which doesn't require jailbreaking, so i installed it. It did take twenty minutes or so, but it worked flawlessly. (I did panic a little when that first "Connect to iTunes message popped up, since i'm at work and couldn't restore from here). however, my phone came back up fine and i've installed six more apps.;)
andrew79
Aug 27, 2007
Apptap is the way to go. Trust me. It's super easy.Took me 3 minutes to jail break. Just remember to backup/sync your phone before you do anything and also transfer your pictures. Just incase you need to restore you will loose your pics .
DoubleD
Aug 31, 2007
68
New Orleans
so is will apptapp allow me to make the changes I want to make? icons/homescreen background/ringtones? Or do I need another program?
DoubleD
Aug 31, 2007
68
New Orleans
OK I have apptapp installed now so whats the next step?
I want to change my icons, change the homescreen background and add ringtones
Thanks for the help!
DD
DoubleD
Aug 31, 2007
68
New Orleans
OK I got Summerboard 2.0 installed and am using there themes which are pretty cool but I'd like ot create my own theme and load it any one know how?
