Confused with jailbreaking 3G
brooke03
Aug 31, 2008
104
33
Memphis, Tennessee
I have a new 3g and I'm attempting to use winpwn... but everything says 2.0 and 2.0.1... iTunes tells me my phone is running 2.0.2. Does that mean I have to wait for a new version, or am I just lost?
firewire
Nov 4, 2007
941
17
Download winpwn 2.5. It's the latest version and it allows you to jailbreak 2.0.2. I just did it last night. Worked like a charm.
blazew0n
Aug 19, 2008
121
Did it today, and love it. Really recommend it. I have it installed with cydia and installer. Used Expert Mode on winpwn 2.5. Follow the guides and youtube it. Great tuts. that show you every step.
daddyd302
Jul 13, 2008
108
Read what I wrote here. It's really easy if you know how to follow a few instructions.
Jul 6, 2008
25
I've got a couple quick questions. I read that if you sync once jailbroken your backup will acutally still have a trace that it was jailbroken. If you backup, and then take a copy of that backup file and store it in a different folder will it then be fine for restoring the phone later if necessary?
Also for some reason as I read through the tutorials I am missing where Cydia and Installer actually get on the phone are they added as part of the custom firmware? Sorry I'm sure I'm just missing something small. also is Springboard installed or is that a separate step with the installer?
TIA.
