contact syncing problem
RylenolFlu
Feb 18, 2008
69
Okay, so I just got my iPhone activated but I can't figure out how to get all my old contacts onto my iPhone (had a razr with a SIM). Anyway, can anyone guide me in the right direction or am I going to have to add everyone back in manually? Much appreciated.
jlhollander
Aug 17, 2007
175
Chicago, IL
Unless you used a program called motorola phone tools to import all of your contacts onto your computer, and then sync them with iTunes, or you are using the same sim as what was in your razr, you will have to re-type everything into your iPhone.
RylenolFlu
Feb 18, 2008
69
it's impossible to use the same sim on the iPhone right? considering it can't inserted into the iPhone?
anyway, thanks for the response, looks like I'll be doing it manually.
