contacts sync from Outlook 2007 through iTunes help :|
demonrage
Nov 26, 2007
i'm using iTunes to sync up with outlook 2007 contacts. it syncs (and by that i mean takes space and time)
but on the phone itself when i click the bottom left phone button and go to all contacts it's totally empy.
if i add a contact manually and then go back to all contacts it's still empty, if i add that contact to favorites i can see'm in the fav tab, but i'm never able to see any names in the "all contacts" menu.
is there something i'm missing? an option here or there to fix this?
thanks in advance :)
lukeules
Nov 9, 2007
at the top there is a groups button, click that and make sure you have the correct contact group selected
demonrage
Nov 26, 2007
do u mean in iTunes? in the sync menu of iTunes i ge to chose outlook only, but the group selection is dimmed.
lukeules
Nov 9, 2007
No i mean on the iPhone itself. At the top left of the phone "contacts" section.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
I don't have a groups button in my contacts. I wonder if that is put there when you sync with a Mac and not Outlook on a Windows machine? On the Contacts section I have a plus sign to add a new contact and then the list of contacts but nothing else at the top.
sl0ppyshat
Oct 2, 2007
178
You are going to have to export you contacts and save it as a file then using windows address book, open you newly saved file and now you will be able to sync your contacts with your phone
