Contacts....
diverdown
Sep 12, 2007
971
49
NYC
I had my iPhone setup to sync my contacts with my mobile me (trial service) and I cancelled that service last night (just did not use it enough to justify the 100). Anyhow, when I tried to sync my contacts with address book (on the MAC) iTunes gave me a message stating that it could not sync contacts as the contacts app was open and I should close it in settings.
I checked settings and did not see any option for this. Also I powered off the phone twice and also did a hard boot. I even rebooted the MAC, all with no better luck.
Any ideas?
~S
jptolife
Jul 15, 2007
645
New York City
Umm I really don't know what's going on. What I would try is to uncheck the box that says sync contacts, sync iPhone, then re-check the box and see is that works.
diverdown
Sep 12, 2007
971
49
NYC
Good advice...but unfortunately that did not solve the issue either.
jptolife
Jul 15, 2007
645
New York City
Sorry but I don't really know what could be wrong. I know this is a little bit of an extreme but maybe a restore will help you.. unless it is a problem with iTunes in which case you'd restore to find the same problem.
diverdown
Sep 12, 2007
971
49
NYC
I know a restore will help, I was just wondering if anybody else experienced this problem and may have found a solution.
