Convert files in 3, 2, 1...
testmenow
Sep 17, 2007
Finding the right all-in-one video converter is hard enough without the app expecting you to know the file types you're converting to and from. MediaCell iPhone Video Converter takes the guesswork and grunt work out of it with a simple three-step program for converting a slew of video file types.
Like the solicitous app it is, MediaCell iPhone Video Converter auto-optimizes screen size, volume, and other output variables for your device.
Check it out at:
http://dw.com.com/redir?pid=1070999...://www.download.com/3001-2194_4-10709997.html
jayeden
Sep 13, 2007
17
Check it out at:
I have tried this one, i don't like it.
By far the best is,
Videora iPod Video Converter
You tell it what type of ipod/phone you have, and it adjusts the setting automatically. It also gives you the option to do it the tech savvy way.
Easiest interface, fast converting, best program to do it all.
http://www.videora.com/en-us/Converter/iPod/
AND ITS FREE!
