Converted video file ....no sound in iPhone
edwardlotz
Jan 29, 2007
27
I converted a video file to ipod specs....it play without issue in iTunes but when I sync with iPhone...there is basically no sounds....there is some type of small scratching.....but no vocals music etc.
Any thoughts on this....I did notice that the volume is kinda low in iTunes but I wouldn't think that cause no volume in iPhone.
Redfor
Jul 31, 2007
301
Fort Knox, KY area
Something may have happened to it when you converted it. What did you use to convert it? And when you converted it.. Did you have the correct Audio files checked?
edwardlotz
Jan 29, 2007
27
I used iSquint I believe...didn't see anything for sound....just the check boxes for h264, ipod and add to iTunes.
