converting shows for my iPhone
DiscoJoey
Jun 5, 2007
307
i wanna compress my TV shows and movies for the iPhone so they fit the iPhones screen perfect and will be as small as possible. i was hoping some one could tell me what format would be best, and what size would fit the iPhones screen perfect?
thinkart
Jun 16, 2007
212
Mid-MO
MPEG 4
if it will play in iTunes, it will play on iPhone
Standog
Jun 26, 2007
97
If you're on a mac try VisualHub, if you're on a PC, I really can't recommend anything to you.
