Converting SWF files
Toxic Gecko
Mar 29, 2008
51
I have Magic Video Converter (full, purchased) on my PC and I am unable to convert the SWF files I have. I emailed the company and they said the error message I was getting meant the SWF file contains action. I have no idea what this means. I'm guessing some sort of block or something? Is there any way to convert an SWF file that contains action or a way to remove action from the files I have?
Toxic Gecko
Mar 29, 2008
51
Thanks for the replies everyone. I'll have to check these out.
sheelz
Jan 13, 2009
58
I use a free program called flv to avi - don't know if this'll help
Maddox
Mar 17, 2009
Hi! Have the problem been solved? May I know the reason?
I haven’t had that problem while converting swf files. and I use iWisoft swf to video converter.
floxir
Oct 29, 2007
Action stands for action script, it enables you to interact with the swf animation. Flash (SWF) is different from flash video (flv), you cannot convert flash swf using flv converters.
styfle
Mar 31, 2008
3,381
You probably wont be able to convert swf with action scripts at all. More of a program then a video if it has those scripts.
Trestan
Apr 9, 2010
Usually I use the program Flash to Video Encoder, to me has very much helped.
hatetea58
Apr 14, 2010
I also have no idea what that means. But u could try some other free video converters to help u, such as handbrake, megui, mpeg streamclip, any video converter etc
Trestan
Apr 9, 2010
Usually I use for comverting SWF files program there is Flash to Video PRO.
