Converting Video For The iPhone
Jun 28, 2007
Long Island
Hi I will be getting an iPhone in the next couple of weeks and was wondering how should i convert the videos i want to put on my iPhone. If I convert the videos for the iPhone the same way i do for my iPod will that be fine. Or should i convert them special for the iPhone?
BIGTIMEBALLER504
Jul 9, 2007
122
same format as the ones for Ipod if u have converted some for the ipod u can use those for the iPhone too
ZJH90
Jul 26, 2007
105
San Francisco!!!!
If you are using a Mac, you can put the video on the movie section of iTunes. From there, select the video, then go up to the top and click "Advanced", and go down to "Convert selection for iPod". Let it do it's thing, then delete the original video, and Tada! You have a video perfect for an iPod/iPhone.
