CONVERTING VIDEOS IN iTUNES FOR iPOD/iPhone
doron
Apr 17, 2007
1,141
tampa, FL
...yeah i used handbrake to encode this dvd to mp4...i imported it into iTunes and then syncd my iPhone and the mp4 wouldn't load for some reason...so there's an option Advanced>Convert selection for iPod...i did it with a mp4 that was about 17sec...it seemd to wrk...i'm converting a mp4 which is about 58min and its been converting since 8am, its now 1:21 pm...man does it usually take this long?!...man!
Rumdada
Sep 23, 2007
25
Check it out go to pspvideo9 its free software converter your mpgs or ne video format to mp4 then just put it in iTunes then sync it to your iPhone :) if u need ne more help lemme kno
doron
Apr 17, 2007
1,141
tampa, FL
Yes. It appartenly takes a G4 about 10 hours to burn a hour-and-a-half-long video with Handbrake from what I've read.
Kevin
ah man, i took a while...about a good few hrs (4 1/2 to be exact)...well, i guess its worth it for what its worth and the end results...good lkn on the post...
doron
Apr 17, 2007
1,141
tampa, FL
good lkn man..so what's the timin' like on pspvid-...timin' is everything wit' me...naughmeen:cool:
Rumdada
Sep 23, 2007
25
The ish is fast but it depends on your comp speed n settings i usually knockout a music video in about 5 mins
doron
Apr 17, 2007
1,141
tampa, FL
good lkn again...how bout full length movies...like 2hr plus joints...
Rumdada
Sep 23, 2007
25
i converted the movie 300 in about and hour on high quality but everyone should really use this software it can convert ANY movie format
