Copy movie to iPhone
nydmx
Jul 17, 2007
92
I am at work and I want to copy a mp4 movie to my iPhone, but when i try to sync its telling me that all my files will be erased. Please help!
This is not the same pc i use to sync on a normal basis
princess_80854
657
You can't sync with two computers using iTunes. If you try to sync on a computer other than the once you normally use, you will have the issue you are having.
dsuppa
Jul 3, 2007
208
New Jersey
www.dfsdesigns.com
Unfortunately you can't do it. Seems like Apple took this idea from the Zune, that was a PITA so sync and so is this. Other than that I love the phone.
I could have sworn I was able to plug my iPod into anyones computer and put stoff on there w/o blowing everything else out
TrippalHealicks
Mar 2, 2007
1,341
Think about what the word "synchronize" means.
It means that the iPhone will be set up like the folders you select on the computer. Meaning that if you have folders A, B and C on the computer, then folders A, B and C will be on the iPhone, in the same structure.
So, if the files aren't there, then it's gonna try to mirror what's on the computer, on to the iPhone. Meaning, if your "tunes" folder is empty on the 2nd computer you sync to, it will empty the folder on the iPhone, as well.
dsuppa
Jul 3, 2007
208
New Jersey
www.dfsdesigns.com
True syncronization would copy the missing files onto the new machine and the missing files on the iPod from the machine. So that both the computer and the iPod match each other.
nydmx
Jul 17, 2007
92
I understand that, (regarding sync), but with my ipod i was able to drag a song from my work pc and place on the left pane were my ipod was listed and it would copy the file, with out syncing the whole thing.
I guess that is what i am looking for, just to copy one file and not sync,
wildonrio
Jul 4, 2007
2,002
Provo, UT
I think in the sensen of iPod/iPhone synchronization, it just looks at what's on the computer and makes the iPod/iPhone match it. So if the computer has less files then the iPod/iPhone, then the syncing will delete those files.
TrippalHealicks
Mar 2, 2007
1,341
Right, it does what Wildonrio says, and pretty much mirrors what the PC has. So, it's not 100% REAL Synchronization, it's more of "Mirroring" the PC's selected drives.
Martlet
Jul 11, 2007
145
Yes, this is where the iPhone differs from the iPod. Manually managing your library is an option on the iPod, but not on the iPhone.
On the iPhone, all your music really does have to be on one computer.
Similiarly, the iPod can be used in disk mode to store files, the iPhone doesn't have a disk mode.
