Copy MP3s from hard Disk to iPhone
Nov 27, 2007
Hi All,
I am getting an iPhone soon.Heard that have to get songs from ITune for the iPhone. I have so many mp3s in my computer. I would like to copy them to the iPhone. Is it possible? Is there a software for that? How can I copy mp3s from the hard disk to iPhone?
Cheers:laugh2:
smitty24
Nov 13, 2007
81
Lakeland, FL
just drag your files into iTunes and it will auto convert them, then just sync to your phone.
Done.
garymooks
Jul 18, 2007
31
Hi
You will need to organise all your MP3's in iTunes software first as playlists.
Then you can sync all the playlists from iTunes into your phone.You don't necessarily have to buy from the iTunes store to sync mp3 with iPhone.
HTH
Nov 27, 2007
Hi,
Thanks for the support. Wont there be any problems playing them in the iPhone. No kinda of protection to check that the songs are downloaded from the iTunes Site?
Cheers
smitty24
Nov 13, 2007
81
Lakeland, FL
Hi,
Cheers
no. i have about 30 ripped cds on my computer. just dragged them to iTunes and synced up.
astrolux
Sep 11, 2007
40
MP3 is the perfect format for moving. Once it's in MPEG4 it seems you are screwed.
