Copy Music From iPhone
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
if you have a mac look for a bit of software called iPhonedrive. Don't know about Windoze but there is an equivalent
There are several different windows programs that will allow you to pull music from your phone. iPhonebrowser is one (free) as long as your phone is jailbroken, if not, you can use a program by Tansee called iPhone Transfer. It costs money but allows you to pull music, ringtones and video off the iPhone without having to use iTunes.
http://www.tansee.com/iphonetransfer.html
pyrowizz
Jun 26, 2007
11
iPhoneDrive works great. and If you down load the demo and turn on the advanced setting to access more in the 'disk' you can follow go to the 'music' folder where all of your music, and videos are located.
If you open the files into iTunes they will have the correct name, don't worry.
You don't need the full version to get all of this. e-mail me if you want more help.
