Copy & Paste Clipboard Widget is a Welcome Addition for Your Notification Center
Napoleon PhoneApart
Jun 19, 2007
33,449
4,536
Upper Marlboro, MD
Copy & Paste | Clipboard Widget, by Jan-Niklas Freundt, is a non-volatile widget that can store multiple copied items to your notification center.This is an item that has been long-awaited by a lot of people, and now it can be implemented without having to jailbreak.
There is a trick to copying more than one entry to the clipboard in the widget. When you wish to save a selection of text to the widget, tap on that text, which will have a green "+" circle to the left of the text. This will slide the text down to be saved in the widget and will now have a red "-" circle to its left. Just repeat with all subsequent text saves . All these copied entries will survive a hard reset, too.
App Store information here.
ZR_Yancy
Jul 11, 2008
3,982
737
If I attempt to copy more than 2-3 images, it loses everything in the clipboard. That damn 1gb RAM again. Maybe it's a bug. If I open the app, I can see the images but not in the widget. I emailed the developer.
