couple questions...
mrq
Nov 12, 2007
hello i was planing on buyin an iPhone and getting it unlock to tmobile. but i was wondering.i have i tunes 6.0.4 can i update it to 7 wit out it messing up the phone? some guy told me never update the ituens it might brik the phone?
Chris716
Nov 29, 2007
807
IL
im not sure but i don't think it matters what version of iTunes you have as long as its compatible with iPhone i thought it had to be 7 something to work for iPhone. And another thing your going to want to get an iPhone with 1.1.1 or lower for it to work with tmobile
mrq
Nov 12, 2007
yes thanks for the quick response... yes i was reading the other threads and found out i cant unlock the new fimware 1.1.2..:( unless i have 1.1.1.. so the way u can tell is to look on the box and the 4th n 5th number should be lower than 46 and thats 1.1.1 fimware?
Chris716
Nov 29, 2007
807
IL
yeah no problem.. Only way to get a 1.1.2 otb to work on another provider is to get turbo sim but i hear they are hard to get...
mrq
Nov 12, 2007
yes... do u think i att store will have some old vers still in stores? i might call areound o nthat
Chris716
Nov 29, 2007
807
IL
theres an Apple store here in chicago that has some 1.1.1 well they did last week when i called. So i assume theres still some out there that will... Just call the smaller att stores and see what they got.. good Luck...
mrq
Nov 12, 2007
i called around couple place they didn't kno what i wad talkin about then.. one lady goes your gonna have to get it from Apple...
Chris716
Nov 29, 2007
807
IL
tell them to look at the iphonoe box and on the bottom where the serial number is ask them if they have any where the serial number is less 46 on the 4th and 5th number
mrq
Nov 12, 2007
ok im gonna go try and go the the store near my house and let them check. 4th n 5h number of serial should be less 46
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Oh good. Mine is 44. Should make jailbreaking a little easier for me when I get to open it on Christmas.
Chris716
Nov 29, 2007
807
IL
youwill have no problem at all doing it unless you accidentally upgrade to 1.1.2 lol
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Geez I hope not! I assume the firmware updates are the same as the iPod where iTunes asks you if you want to upgrade and you can either accept or decline?
Vulture
Dec 12, 2007
so if its 46 youre screwed right? my sister just picked one up for me after mine bit it at the beach and its a 46. is there anything that can be done to use the phone besides using att which doesn't exist in the country I live?
Chris716
Nov 29, 2007
807
IL
um... that would be a negative unless you wanna hardware unlock which i wouldn't recommend unless your good with a soldering gun or on ebay look for turbo sim
