Cover art doesn't appear after iOS 8.4.1 upgrade
RVojvoda
May 10, 2010
On the border
OK. So I upgraded my software and now my cover art does not appear either on my ipod touch or on the display of my vehicle. Any suggestions?
5,580
This is a bug with Apple Music. Are you using Apple Music? If not, toggle off iCloud Music Library in the music settings on your phone. If this doesn't fix it, I'll post some additional things to try.
RVojvoda
May 10, 2010
On the border
I don't have an iPhone but rather an touch. I checked music under settings and there is no iCloud switch. But I did switch off iCloud under the iCloud setting but to no avail. More suggestions would be appreciated. Thanks.
5,580
No, that's the wrong place. You don't want to turn off iCloud. You just need to turn off the iCloud Music Library.
1. Do you have this toggle?:
Settings > Music > Library > iCloud Music Library > Off
2. Are you using Apple Music?
RVojvoda
May 10, 2010
On the border
I do not have that setting available to me. I turned off apple music and it didn't make a difference.
5,580
In iTunes on your computer, press the music icon in the upper left, then My Music on the left side of the controls in the center, then select Songs in the upper right. Check the boxes for Show Artwork and Always Show and sync your iPod.
If the album art still doesn't show up after that, unsync all of your music through iTunes and then resync it.
RVojvoda
May 10, 2010
On the border
Tried your suggestion and have cover art in iTunes but still no on the iPod touch.
5,580
Tried your suggestion and have cover art in iTunes but still no on the it ouch.
Did you unsync all of your music from the iPod and then sync it back on?
RVojvoda
May 10, 2010
On the border
Tried hard reset and resend. No good. Did a total reset and a resend. Success!!! Thanks to everyone for the help.
