Cover art not on iPhone but is in iTunes?
detz
Jun 28, 2007
31
Sometimes the cover art shows, sometimes it does not on the iPhone. It looks fine in iTunes on the computer and I've removed it, added it and synced but it does not show up for this one album, any ideas?
Iwantmymtv35
Jul 2, 2007
134
Hm...did you purchase the songs through iTunes? Otherwise, it may not be recognizing them on the iPhone because it has no where to pull the original cover art from.
detz
Jun 28, 2007
31
No, they are my own CD's. When I choose 'fetch cover art' it can't find the CD so I downloaded it manually and did it.
Iwantmymtv35
Jul 2, 2007
134
Well, I have no idea. I'm sorry.
detz
Jun 28, 2007
31
OK got it. If it does not sure up you can embed it into the songs and it will. Select all the songs on the CD, right click, Get Info and set the Album Art
16bars
Jul 3, 2007
I had the same problem. I took all the songs out of iTunes and put the covers on one by one. Very time consuming but so satisfying in cover flow! Another thing to do is to go into the iTunes store and look at what they have the title of the album as and input that. Then ask to get artwork.
DHNF
20
How else would you get the cover art there? That's how I did it and I'm noticing this problem as well. It shows up while I'm scrolling through my albums in the cover flow thing but when the song plays it just shows the musical notes...
detz
Jun 28, 2007
31
iTunes just had it, or if there was a cover.jpg in the folder it would pick that up I guess.
Biggie
Jun 30, 2007
I'm new to the whole iTunes/iPod/iPhone thing and one thing I noticed if you import your own songs say from a CD. Of course you will sometimes have to add your own cover art for that album, but heres the thing you will have to add your cover to ever song in that album!
The first time I played with this and iTunes did not have the cover for my album I would of course download the album picture from the internet. Then I would click on the first song and click get info and then add the cover art. I would then go into my iPhone and start playing that album I noticed that after the first song would play all the other songs would have that default placement holder icon. So what you have to do is basically add the cover art to every single song in that album.
I hope that helps...
mrpacijr
Jun 24, 2007
9
I've got the same problem. My artwork shows up on iTunes but SOME of them don't show up on my phone. It did for a while and then today for some reason Some of them disappeared. I can't figure out why it went away?
T-HAN
May 11, 2007
85
I am having the same issue. On my computer iTunes shows cover art, on the phone it does not!
HELP!
invincible569
Jun 30, 2007
79
On mine... I can change some mp3's. but not others. It doesn't give me the Artwork tab. Does anyone know why?
detz
Jun 28, 2007
31
what works for me everytime is select all the songs for the cd, right click on all off them and choose get info. In that screen set the cover art
goherd90
Jul 5, 2007
14
exactly...this is awesome as I had a bunch of old cd's that did not have artwork. I simply found a pic of the album cover on google search..saved it to my pics...then I was able to get it from iTunes. Now all my albums have covers...thanks everyone
Maaz
Jun 30, 2007
584
LA California
i just got my iPhone today and the same exact thing is one of my problems.
