coverflow help!
Jan 5, 2008
hi there!
can anybody help me please?
i can not see the covers of my cd in coverflow,only a grey square!
i have 6 albums already in there but can only see one with the artist picture.
please help
thanks
oliver
KNK
Jul 22, 2007
2,391
Stevenson Ranch
hi there!
please help
thanks
oliver
Are those your own CD's? If so you do this:
This is pretty simple to do and you don't need a iTunes account:
Step1. Find the name of the song you want to add album artwork for (lets say the song is Alicia Keys " No One" )
Step 2: Go on the internet and search for Album Alicia Keys No One ( I personally find Amazon is a good source for finding almost any album)
Step 3: Go to the link to the Album save the Album cover picture and might want to write the Genre, Year Album Release, that kind of stuff if you want I mean
Step 4: Then Go To iTunes and Select the song you want to add the artwork for and right click on it and select Get Info
Step 5: Go to the Artwork tab and browse to where you have stored save you the Album Artwork and Select it
Step 6: Click Ok then Sync your iPod touch or iPod (which ever you have) and you album artwork will be on your iPod touch or iPod when you to select them on your iPod touch or iPod
Note: The procedure is the same for any ipod device
Jan 5, 2008
coverflow
yes cd are my own.
the thing is when i go to info(ipod touch)it tells me all the things
like artists ,songs(everything).but i can not see the cd picture in coverflow.
only grey square
thanks
oliver
iStealth
Nov 5, 2007
421
yes cd are my own.
only grey square
thanks
oliver
As KNK says do those things in iTunes first then once it is iTunes, sync your touch and wa la... it should work.
