CoverFlow out of sync
missaych
May 29, 2008
When I sync my music files coverflow isn't showing the correct album art for some of the music. Anyone else have this happen?
i robot
Jan 29, 2008
747
from time to time my coverflow will lag and disappear but I pit this down to processing speed. Have you tried the old power off power on
missaych
May 29, 2008
Tried that and it didn't help. Tech support is at a loss. Took it to the Apple store and they replaced the phone. Trouble is this one is doing the same thing. Called Tech support again. Un/Re-installed iTunes. That fixed the problem but who wants to have to do that repeatedly. I suspect the problem is related to the syncing errors. Maybe one of the music files is corrupted. Could that cause the problem?
Using:
current version of iPhone firmware and iTunes
PC - XP
winchaman
Oct 19, 2008
i have this same problem. Bought my iPhone yesterday, and i have my iTunes coverflow customed and uptodate, and when synced on the iPhone it doesn't sync all of them. i turned it off and all, but its still there. And how do you re install iTunes? Is it the only solution?
