coverflow problem...
Chris716
Nov 29, 2007
807
IL
just go to iTunes and highlight all your songs and right click on them and click get album artwork.. then you just re sync.... but if you have anything not spelled the same way spaces included as iTunes does it will not find it...
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
If some of the songs are part of the same album, but aren't showing up in the same coverflow album, you should choose "Part of Compilation" in Get Info for the songs that should be grouped together and that might help.
Chris716
Nov 29, 2007
807
IL
OH yes thats right i forgot to add that....
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
if iTunes can't find the cover artwork, just google-image search for whatever pic you want and then add it through the info option in iTunes....
Chris716
Nov 29, 2007
807
IL
thanks i didn't know you could do it that way....
