Cracked Rear Glass, Replaced Very Cheaply!
Hondamaker
May 14, 2007
9,946
655
57
Fairborn, Ohio
First off, 'very cheaply' doesn't sound right. Is it?
Secondly, and back on topic, the other day I took my iPhone 4S to work sans case, which I never do. Of course it fell out of my pocket and into a metal container full of iron camshafts.
On my lunch break I found a replacement back on eBay for $8.99! Got it today and replaced in a jiffy.
So, if you crack the rear glass, replacement is cheap and easy. Crack the front, you're in trouble.
Hondamaker
May 14, 2007
9,946
655
57
Fairborn, Ohio
Nice fix Jack, and that IS cheap at 8.99...was it easy to replace the back glass?
Pretty easy, although they forgot to send me the pentalobe screwdriver so I had to slightly modify a tiny flathead screwdriver to get the microscopic screws out. Then you slide the back up towards the top of the phone about a quarter inch, and it pops right off.
Was it an OEM rear glass panel?
As far as I know. It looks exactly the same as the original, sans the cracks.
  • Like
Reactions: Muckcityjustin
