Crash crash crash
MuddyPaws
Oct 3, 2009
986
31
iPad2 iOS5
Apps crash all the time. Safari is hardly usable anymore. It will crash about every 5 minutes. I have tried everything. Any of you find a fix? If not, I hope Apple gets their crap together and fixes with a iOS update soon.
I don't have an iPad 2, but I know a few people who do and theirs are working just fine on iOS 5. I suggest restoring to factory settings.
InyigoMontoya
Jun 17, 2011
311
Indiana
Update mine to iOS 5 out of the box and have had no major issues. Safari works fine, ESPN app works great. Can't say I notice the same performance issues you are seeing. I did a hard reset right after installing iOS 5 and syncing. I agree with Europa. Restore to factory - update, sync and hard reset.
theorioles33
Jul 21, 2007
925
135
USA
iPad2 iOS5
I would do as everyone is suggesting. Restore and then restore from a backup. If it still happens, you could have a corrupted backup. Try to restore again and set up as new. If you still have issues, it may be the hardware. My wife and I and a friend at work are on iOS5 and everything seems to be running great. As a matter of fact, I have been on iOS5 since the the 5th Beta.
Good luck!
MuddyPaws
Oct 3, 2009
986
31
Wow....like I have said before. iOS is the new windows. For anything wrong with it the first suggestion is to restore. Close all windows and reboot. That don't fix it, format and re-install. LOL
There is a 9 page thread on the Apple support site about the same thing, so it's not just me.
You could try resetting all settings first.
15,385
1,023
I had an iPad 2 for a while that was on various iOS 5 betas, and never experienced anything that bad.
If someone recommends that you restore windows or OSX (not just limited to XP), it's because they don't know how to actually fix the problem. When we recommend to restore iOS, that's because it's the only option. We don't have the ability of a disk utility or checking .plist files or anything like that.
  • Like
Reactions: Rugaby
greasemuntney
Apr 4, 2010
103
Alabama
My 1st gen ipad crashed plenty of time son iOS 5 STOCK. checked around and found out that everytime I had iHeart Radio running in the background many different apps would just crash back to springboard. Goto General>About>Diagnostics & Usage>Diagnostics & Usage Data. open the file inside there and see what it says was running and using your memory when your crash occurred. This helped me find my issue. Hope it helps you too.
  • Like
Reactions: Rugaby
iP5
Sep 7, 2010
2,964
136
Toronto
Sounds like a great goto procedure before the last shot restore. Have to remember this one for future use. Like my new habit of shift dragging the keyboard for numbers.
EiC is great for such little tips and tricks. :D
Sent from my Desire HD using Tapatalk
MuddyPaws
Oct 3, 2009
986
31
yes, I'll have to check what is running on crash.
What is this shift drag you speak of?
iP5
Sep 7, 2010
2,964
136
Toronto
Something Europa pointed out about the keyboard in iOS. I like being able to long hold a key to reach it's alternate sets and wish this was ported to iOS. Not as good but definitely a shortcut, in iOS, you can swipe from the shift key to an alternate character and the keyboard returns to normal mode when you lift off the screen. Definitely better then having to tap the shift to return to normal. Especially useful with my passwords.
Hope that makes sense to you.
MuddyPaws
Oct 3, 2009
986
31
Oh, I see. slide from the shift to a capital leter and slide from the number button to get a number.
Press the 123 key but don't let go. Now drag your finger up to a number and let go. The screen will automatically go back to the QWERTY keyboard. It's a faster way to put in passwords that have numbers and letters because you don't have to tap ABC after selecting a number.
And make you switch keyboards ten times if you wanted to type ten numbers? No. That would be annoying. It has never been that way.
greasemuntney
Apr 4, 2010
103
Alabama
After seeing the crash report I stopped using iHeart Radio in the background and have had no more crashes. So helped me out. Love this site too. Great information here and plenty of people that doesn't mind helping.
