Crashed!
l1nk1n
Jul 6, 2007
while i was sending an e-mail. the Apple logo appeared.
i turned it off/on/reset. only the Apple logo appears.
help? :(
alb0zf1n3st
Jul 2, 2007
624
You held the home botton and the sleep for bout 10 seconds and did that reset? you might have lost stuff.. or maybe the battery is low and wont start up? did you check the battery?
l1nk1n
Jul 6, 2007
what do you mean lost stuff?
did all that. yes, the battery is full!
alb0zf1n3st
Jul 2, 2007
624
Im saying maybe if all the options I listed are fine then you probably had the first phone that crashed and wiped out but lets wait and see if someone that knows better will post a solution because I would like to know myself.. sorry to scare you
l1nk1n
Jul 6, 2007
i'm not scared. it can be replace easily. in this case this would be my third iPhone, the first one had a bad speaker(can't hear anything) and they replaced it.
help! if not i guess i will just get it exchange.
