Custom carrier logo on 2.0.1 - How to?
olik
Aug 13, 2008
Hi,
I am trying for about six hours now andcan not get it to work.
I am on T-Mobile Germany with an iPhone 3G 2.0.1, jailbroken and Cydia is on it.
I tried the T-Mobile icons in Customize, but neither the bars nor the carrier logos show up under "Customize Images/Sounds" - The right permissions are set, as some other themes do work. Applying the icons directly from "Theme Browser" doesn't work either.
I also tried the carrier packages from Cydia, I also restarted and re-inserted the SIM several times, all without success.
I looked via SSH - All the carrier logos I want ARE definetely in /System/Library/Carrier Bundles - But why doesn't the iPhone use them?! Do I have to replace anything to get them to work? Custom texts with "Make it Mine" do work, but I want to have the T-Mobile logo in the top corner (or some custom made logos I found in some boards).
So, can anyone help me out with this?
It would also be great to ONLY get the T-Mobile logo if I am actually in the T-Mobile Germany zone. I am in Holland often and want to see if I am in Holland zone or not.
Thank you very much!
Oli
mjk2
Feb 13, 2008
Find utilities,download Make it mine,follow instructions.You can change carrier name or banner.Enjoy
olik
Aug 13, 2008
Hi,
thanks for your answer, but I already knew that. I do not want to place a custom text, but a custom logo in the top left corner, or at least ANY logo, as I want to get rid of the custom text from the carrier.
Any solutions?
Thanks!
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
Hi,
Oli
Did you check out this page? http://www.hackthatphone.com/20/custom_graphics.html It should help. :)
