custom dialer voices/sounds not working?
Tried to add the "mamacita" custom sounds for my dialer but it fails to works. Does anyone know if this still works? I've been trying it via "Finder" and SSH. Haven't had any luck, so just wondering if it does not work anymore? I'm on 1.1.4 jailbroken. Thanks
H
Hayesimus
Guest
If you mean you used customize 2.0 or whatever, I couldn't get mine to work either, which is why I eventually deleted it.
H
Hayesimus
Guest
well, check the file directory manually. They moved a lot of the files around.
