Custom Ringtone Not Showing Up
Hockey Puck
Jan 22, 2008
41
PHOENIX ARIZONA
I have created several custom ringtones in the past from my iTunes library with no problems. The other day I purchased two custom ringtones using my song list in the iTunes library. They are not showing up anywhere in iTunes, so I cant download to my phone. Any suggestions?
thanks,
Jun 7, 2007
545
Queens, NY
thanks,
make sure the ringtones are in a file format iTunes and the iPhone understands. .m4r is ringtone format...it should show up under ringtones on iTunes..
if not briefly describe how you make your ringtones...and if you purchased some and they are not show up...i don't know, might have a problem there...
