Custom Ringtones in latest firmware
Drtydzn12
Nov 4, 2007
29
Sorry if this has been asked already, but in the latest firmware, are custom ringtones still possible? Using the method that doesn't require any programs? the one where you just edit the file extensions?
nealh
Apr 3, 2008
699
25
is there anyway to create a custom ringtone for text messages
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
If your phone is jailbroken you can change most of your system sounds using iBrickr. I just checked and the text message sounds are included in the list of sounds you can change.
nealh
Apr 3, 2008
699
25
not sure I want to "jail-break" it
nealh
Apr 3, 2008
699
25
how much risk is there that you will brick the iPhone with these jail-break programs?
mrfisch13
Apr 29, 2008
9
why don't i see this program anywere on jailbreak?
i also cant get the SMB themes to work and icant find the fix for that either =(
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Ask on the iPhone modifications forum. This forum is for more general questions about the original firmware. The hackers can help you out, but they usually read the modifications forum first.
Good luck!
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
iBrickr is not run on the phone. It runs on a desktop PC and connects to the phone through SSH. That is why it doesn't show up in installer.
