Customise Carrier with an image, using Zeppelin
fijiman
Feb 13, 2011
832
64
UK
You can use the images that come with Zeppelin or you can just make your own...
Image Dimensions : Width-140 pixels Height - 28 pixels
Make a folder, Choose an image(.png) (with the correct dimensions) and copy 10 into the folder renaming each one :
black@2x
etched@2x
silver@2x
silver@2x-alt1
silver@2x-alt2
black
etched
silver
silver-alt1
silver-alt2
(for Retina type devices you only need 5 images renaming each marked in green)
Using any software tool you like(WinSCP,Cyberduck,iFunbox....) SSH into your iDevice and copy the folder containing your carrier images to Library > Zeppelin.....then exit.
On iDevice go to Settings>Zeppelin>Theme...select your theme, back to Zeppelin and press Apply & Respring
Here's a quick 5 minute image I made...
fijiman
Feb 13, 2011
832
64
UK
Not only is this an easy method.. But I like this, for the ease of storing multiple images and applying on the fly...
  • Like
Reactions: iphonewarrior
larryo108
Dec 22, 2009
182
Yeah. I found it. Bought it. Tried it. Removed it. Second time I have done that in two days. I should just quit while I am ahead.
Those are some wicked small springboard icons you got going on there too.
