customize 1.21 dock issue. HELP
projkt13
Oct 22, 2007
25
Oceanside, CA
so here's my problem:
I have a 1.14 iPhone with version 1.21 customize app. ( I downloaded the app patch to make this work). I don't use the icon order for interface because I manually do it on the interface itself by holding onto an icon and dragging it to where I want it to go. Im trying to use customize to fix my dock. I set it to 4 icons, when I exit and restart it shows 4 icons on dock, but when I click on an icon then exit, one of the icons from the dock always finds its way to the interface itself, leaving only 3 dock icons. I try Many times to re-do the dock numbers but I get the same outcome.
Anyone have this problem? Any help would be much appreciated. Sorry so long.
24trepid
Jan 13, 2008
502
What kind of patch ? I'm on 1.1.4 and didn't install any patch for customize 1.21 (custom). My phone is LOADED with apps, and I haven't installed any kind of patch. Try un-installing the patch........
