Customize doesn't work with 1.1.1?
wincow166
is this happeneing to anybody else?... when i load it it shows the chicken thing then it just goes to the springboard
Rob H
Oct 18, 2007
23
Version 1.13 is working on 1.1.1 for me
patrick_83
Oct 11, 2007
310
Illinois
Same for me i just got my 1.1.1 jailbroke, and i was using it on 1.0.2 :(
jbarrack
Jul 2, 2007
453
New York
www.facebook.com
I read some where that when its loading wipe your finger over the screen and it will load. Sounds strange but it worked for me with 1.1.1.
jcit
Sep 18, 2007
Canmore CANADA
Customize Changes not taking effect?
Customize 1.13 upgraded via Installer app on a 1.0.2 iPhone. Whenever I go in to change some of the icons in customze and try to apply them, they don'y take effect? I've tried uninstalling customize and reinstalling, I've tried rebooting after making changes. I've tried restarting after trying to apply? I'm at a loss... Anybody else experiencing this? The rSBT part works fine in changing the order of icons etc.
Hmmmmmmmm.....:sick:
Rob H
Oct 18, 2007
23
The RSBT works and so does custom sounds and the Icons like battery and task bar etc for me. Maybe try uninstalling and re-installing it ? I got it through Installer, not Ibrickr maybe theres a difference
DanUC6
Jun 2, 2007
136
Happened to me to. Just uninstall and reinstall and before you do anything reboot the phone and then try it again. I did this and it worrked.:laugh2:
scandalex
Sep 16, 2007
771
I'm to the point that I am scared to use customize. It seems like it has it's good points, but just too glitchy to make work properly.
yerx
Apr 12, 2007
19
mine worked after a restart.
