Customize is Now 2.0 Compatible/ Download Link Available
princess_80854
657
Customize is Now 2.0 Compatible/ Now Available in Cydia
Taken from CustomizeApp.com....
QUOTE
"Customize is now compatible with Firmware 2.0! There are still a couple of bugs (About page and Comments still not working), but all the good stuff is in there. You can download it here, or you can install it via Cydia (and Installer, soon)."
EDIT - Link Updated with Customize 2.1.1
EDIT: It's now available through Cydia.
idle0095
Mar 28, 2008
55
ya hoepfully because even on the website it says its available on cydia already. this is why installer is the best because you can manual enter the source and get the app right away. not having to wait for some one to do it.
idle0095
Mar 28, 2008
55
i have no idea. all i know is this is supposed to be on cydia and it is not. again this is why installer is the best. who in there right mind would make a program and not allow the user to change or add sources? again installer is the best
adambodkins
Jul 15, 2008
112
where can we get installer for our 3g's?
jslappa
Jan 18, 2008
225
Installer 4.0 is not out yet. If you are on firmware 2.0, you cannot get installer, whether you have the old iPhone or the new 3G iPhone. Sorry.
Also, I just tried to SSH Customize into my 3G iPhone, and can confirm that the splash screen with the spicychicken loads, then the main screen loads for about 2 seconds----Then crash back to home screen. I even tried changing the permissions to 0775-versus the standard 0755.....still no good. Has anyone got it to work on their 1st gen iPhone? I have one, but the wife has it today.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
you need to upgrade to Customize 2.1.1 (per thespricychicken)
Chris.Carter770
Dec 25, 2007
99
when u run it for the first time it will crash and take you to the homescreen 2 or 3 times before it will actually run. See if that helps your problem.
princess_80854
657
QUOTE
"You can download it here, or you can install it via Cydia (and Installer, soon)."
They're not saying that it 's available through Cydia right now. It will be there SOON. I believe they posted the download link for those who don't want to wait for it to show up on Cydia and those who are comfortable with manual installs.
Also for those who are downloading and installing manually, there's an updated link to the Customize 2.1.1 download in my first post. It should stop all the crashing problems that have been happening.
Enjoy!
Jul 21, 2008
i've got the program to run and to install themes..
it just doesn't seem to work when i try to apply the themes to my device...
Jul 28, 2008
yes, the only thing that it's applying is the lock wallpaper... :(
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Have you changed the permissions of the Customize.app folder to 0755? Also have you gone into the folder and changed the permission of Customize and Customize_ permissions to 0667?
Jul 28, 2008
I had set the enitre directory including sub to 0775... let's see what happens your way... :)
yes... same thing, just the wallpaper has changed...
Strings won't change either...
mac3194
Jul 21, 2008
9
i downloaded the file but i have no idea how to put it on my iPhone any help would be appreaciated
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
My bad, the Customize.app permission should be 777. My fingers were not typing what i was thinking :oops:
