Customize not working PLEASE HELP ME :(
bones66
Mar 30, 2009
Hey I really need help with this. Ive installed customize on my iPhone 3G with cydia and I can get into the app but i cant do anything at all(i cant change text or sound or anything) Ive looked on google and decided this is the best place to ask because i cant find the answer anywhere. I have used the "chmod +s /Applications/Customize.app/Customize_" command in mobileterminal but it says chmod: cannot access '/applications/customize.app/customize_': No such file or directory.
Please i really need help with this.
Ive also tried setting permissions too 644 755 and 777 they don't make a difference
Dec 17, 2008
592
PA
Does it just freeze up on you?
Seems to be just buggy I won't use it.
bones66
Mar 30, 2009
Also, i tried the "chmod +s /Applications/Customize.app/Customize_" command in mobileterminal casesensitive and it now says chmod: changing permisions of '/applications/customize.app/customize_': Operation not permitted
