Customize Problem (FW 1.1.2)
Mar 15, 2008
So i want to change my carrier image, currently it's the ATT logo and ATT next to it. When i go to select another image on customize, i select it, return to springboard, then the phone restarts and the same image is still there. I tried uninstalling customize and everything is still there. How do i fix this?
~thanks
riot984
Dec 23, 2007
22
customize won't change the carrier icon but you can download statusstyle and you can change the carrier icon to whatever text you want. I would recommend makeitmine but you can't get it with 1.1.2 unless you winSCP it into your phone.
-riot
