Customize re: chat balloon
abates21
Jul 29, 2007
Knoxville, TN
I'm using the latest 1.1.1 hack through Safari and have downloaded Customize. What is the best way to change the color of the chat balloons? I did a quick search and didn't find anything.
Thanks!
iPat
Sep 14, 2007
23
There is an image set for Customize called "Designer Image Set" That file contains many colors to use for chat balloons via Customize.
Stevonw
Sep 14, 2007
560
UK
The best way i would say to change is to change them manually at root level, quick, simple & problem free (unlike the latest versions of customize.....especially on v1.1.1)
Both SMS Balloons are located in Applications/MobileSMS (i think)
iPat
Sep 14, 2007
23
^^ or that if you want to be a little more technical with it. :cool:
