Customize SMS Sound Not Working
section8joe
94
I can get the email sounds to work in CUSTOMIZE but I can't seem to get the new SMS message alert to change. When I get a new message the default tone from my iPhone is played. How do I change this?
What app do I use to add my own personal sms message alert tones?
Stevonw
Sep 14, 2007
560
UK
What firmware are you running?
section8joe
94
1.1.1 on the iPhone and customize 1.13
Stevonw
Sep 14, 2007
560
UK
I don't know how many times it has to be said about v1.1.1 and customize.
Currently it's really buggy and would advise from any further use of it, until it is updated.
enigmanic
Jun 27, 2007
513
SMS sounds will not work with Customize on 1.1.1 phones, since Apple now allows you to choose from 6 SMS sounds. The work around for this is to replace one of the 6 new tones with your own. First, you'll need to convert your sound to a .caf file. Then using your favorite browser program (WinSCP, iBrickr, Cyberduck, etc), navigate to this directory on your phone:
/System/Library/Audio/UISounds
The 6 apple-created SMS sounds are as follows:
sms-received1.caf = Tri-tone
sms-received2.caf = Chime
sms-received3.caf = Glass
sms-received4.caf = Horn
sms-received5.caf = Bell
sms-received6.caf = Electronic
So you'll want to pick one of these to replace over. For example, if you decide to replace Electronic, you'll want to rename your sound file to sms-received6.caf and just upload the file to this directory. Then go to Settings-->Sounds-->New Text Message and select your sound file.
Please note that the SMS name will not change. So if you replaced Electronic with your own custom tone, it will still say "Electronic" in the menu, but will play your custom tone.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Thanks. By the way, "Electronic" is just about the lamest text message alert sound I've ever heard in my life. I can't believe a major corporation like Apple would decide to use such a crappy alert sound as one of their top 6 choices for the most powerful phone in the world. How embarrassing for them. (The other text message sounds are also really bad too.)
wildonrio
Jul 4, 2007
2,002
Provo, UT
By the way, I heard somewhere that if you just use a wave or mp3 file and change the extension to .caf, then it will still play without having to convert it. If someone would please try this and let us all know...
sanjuue
Nov 27, 2007
how can i upload the file to /System/Library/Audio/UISounds directory? I am a Windows based user (no Mac). What program can I use? Pls advise, thnx
wildonrio
Jul 4, 2007
2,002
Provo, UT
WinSCP. The Host is the IP address of your phone, available under Wifi setting, the username is root, and the password is alpine on 1.1.1 and dottie on 1.0.2
sanjuue
Nov 27, 2007
juz ren .tiff to .caf extension...no ned to convert
beat84
Nov 11, 2007
did someone discover how to add the seventh
ringtone for message?
barbary
May 14, 2008
Yes it is true, I just renamed a .wav file to the horn sound above and copied it over to my iPhone using WinSCP - works fine! :laugh2:
BTW for 1.1.4 the username is root, and the password is alpine. :cool:
staceyde
Jun 25, 2008
SMS sounds not working at all
My SMS sounds aren't working at all. I am running 1.1.4 Customize 2.0.... please help.
Katrina
Aug 27, 2008
using cyberduck to connect to my iPhone
Thanks for the help described here.
I'm very new to my iPhone G3 (in Australia) and have downloaded and installed cyberduck but have not been able to work out how to connect to my iPhone.
I would appreciate some help on making that connection so that I can then follow these instructions and get my favourite message alert onto my iPhone.
thanks in advance! :)
Katrina
Aug 27, 2008
iPhone passwords
and the password for 2.0.2?
Katrina
Aug 27, 2008
connecting with cyberduck
it's the same as it's always been... Root. Alpine.
Thanks for the super-fast reply OJsakila.
I feel like this should be the simple part - I'm on a mac, using cyberduck to try and connect
i've tried by putting a path in to where the sounds are or not putting it in
here is a screen shot, i've also tried the other protocols
I would really appreciate if you can work out what I must be doing wrong
the IP address is definitely correct
the error I get for doing this is
seems to me it is saying the username or password is bad
I don't have any third party software on the iPhone - it's a very new phone and my first experience with one
all help I'll be very happy to receive
D-Wade
Aug 26, 2008
69
Singapore
Customized sms alert is only for jailbroken iPhone right?
is there anyway to jailbreak 2.0.2 FW on 3G as of now?
