customize update
reas0n
670
20
Stamford, CT
www.ohitsjustpete.com
after the latest update of the customize app... The rSBT part of the app isn't working... My 5 icon dock went down to 4 and won't go back... Just wanted to see if anyone else was having this issue
Aug 28, 2007
348
i put it on 1.1.1 and it gave me so many problems so i restored a few hours after i jailbroke my 1.1.1 cause of this app messing up the iPhone, im gonna be doing it agian later but im not putting on customize until they fix this issue
djw31
Oct 13, 2007
yeah that exact same thing happened to me. i tried 5 and for some reason my Ipod icon wouldn't show up in the dock. and then i continued to mess around with it and i put the dock number to ZERO and it proceeded to delete 3 of my applications (customize, installer, and summerboard) ne idea how i can get these icons back?
djw31
Oct 13, 2007
ahhhh ic thats kinda weird. ne idea on how i can get those icons that dissappeared back?
15,385
1,089
i was having serious trouble with my ipod icon as well, and then i tried this:
jaayrawr said:
what i did was, i used iBrickr and went to the /System/Library/CoreServices/SpringBoard.app/DisplayOrder.plist
looked for "com.apple.mobileipod-MediaPlayer " and deleted the "-MediaPlayer" part off of it.
re-uploaded it using ibrickr and everythings back to normal
it worked marvelously. I'm not sure if it will solve your 5-icon dock problem, but i wouldn't doubt it.
Ace4261991
Jun 18, 2007
530
that sounds like itll work but when i go to displayorder.plist how do i open it to go to music player app? i donwloaded it and then went to open it and it goes "would you liek to search for a program to popen this file with" sumtin like that
jbarrack
Jul 2, 2007
453
New York
www.facebook.com
Apparently a lot of people have been having problems with this same thing. If you go to www.thespicychicken.com tons of people have gone to complain about it. I wondering where are the image packages they said they posted on installer app. They are no where to be found ... has anyone else found them?
xSoNiCcRaCkErSx
Jun 30, 2007
226
hmmm
im glad mine didn't work.
i tried to install the customize update through installer app and it kept saying i needed to install rSBT which was already installed. I de installed it, then installed it again then tried the customize update and the same thing. my icons were not messed up after de installing / installing however. I guess i wont be able to update until there is a fix.
djw31
Oct 13, 2007
with the new customize update i was able to get my ipod icon back in the dock but i still cannot get 5 icons on the dock
15,385
1,089
open the .plst file in notebook (or some other simple word processor). delete the "-MediaPlayer" part off of that section of text. Save, and upload it back into the same place onto the iPhone. problem solved.
ddrricky
Aug 12, 2007
images
Ok so since we have ALL these options to customize now does any one have anywhere to actually get images from to use in the customize application?
15,385
1,089
go to the installer, and check out the "Themes (customize)" section. You will have to install the community sources if you haven't already.
420greg
Jun 26, 2007
845
Orlando, Florida
I updated my customize today and it told me to uninstall rSBT.
So I did, and tried again and it worked. rSBT now has an icon within the customize menu.
jbarrack
Jul 2, 2007
453
New York
www.facebook.com
Where are the new packages thespicychicken.com said they posted on installer? The new update with new customize stuff is useless without the new image packages ...
rabanjr
Oct 3, 2007
You have to install Community Sources to see all the extra stuff. It comes up in installer.
Works like a charm.
Good luck.
Allan
