Customize v1.21 - iPhone v1.1.3
p911pew
Feb 28, 2008
Northern Ireland
Customize 1.21
I have successfully installed it and it opens:) but it makes no changes?:(
Any ideas.............:sick:
15,385
1,089
I think you have to reset the permissions or something. I'm sure someone else will be able to elucidate.
Bone
Feb 11, 2008
1,214
Originally Posted by apophoenix
I hope I'm not stepping over any toes, but here's what I did to get Customize working on 1.1.3:
1. Install Customize if you haven't done so already.
2. Add this source:
http://www.touchrepo.com/repo.xml
3. Install Customize 1.21 (custom),2
I'm able to change almost everything except for the carrier logo, which is a known issue with 1.1.3. For that, I use Erica's MakeItMine. Otherwise, everything works great with Customize.
you should try this first. if this doesn't take i know of a few other tricks that might get it going..
p911pew
Feb 28, 2008
Northern Ireland
2. Add this source:
You Genius:laugh2:
It works a treat now apart from the carrier logo but i'm not bothered about that one bit.
I am pretty new to the iPhone infact I am pretty new to Apple!
Are there any other applications I should look out for that will make the phone even better?
Cheers Again Mate
