Cyberduck terminal commands?
lman
Oct 18, 2007
632
I found a fix for fontswap, which apparently for many people isn't working. I, however, need to run some terminal commands. But because v blah blah terminal (whatever it is) that you can download on your phone doesn't seem to be working for me (keeps asking for a login and password and root and alpine are the right information) i thought i might as well do it through cyberduck. Is it possible to run terminal commands in cyberduck? How do you go about doing this?
x999x
Aug 6, 2007
1,656
Finder > Utilities > Terminal
type this
ssh root@youriPhonesip
enter the password alpine when asked. (your key presses wont show for security reasons)
Issue your commands, and then just type:
exit
when done.
lman
Oct 18, 2007
632
type this
exit
when done.
Worked perfectly, thanks a lot man
