Cydia "Blanks" package
iSpend
Jan 11, 2008
126
I downloaded the blanks package a little while ago, had to restore my phone. But after the restore, the blanks were still on my springboard.
I can't go into Cydia and uninstall the package, because Cydia doesn't show that's it's even installed (because of the restore). I'm assuming I'll have to ssh to get rid of all of these blanks...but could someone tell me where to look to locate Cydia packages once I SSH ?
eplantz
153
can you just reinstall it via Cydia and then delete it?
if not, press/hold an icon on Springboard until you go into change mode and then press the X to remove it. press Home to exit this mode.
iSpend
Jan 11, 2008
126
Deleting the icons the traditional way doesn't work, for some reason they keep coming back. Even once I reset the phone. Which sucks because they're taking up space, so that I cant see some of my apps.
I'd thought about reinstalling via Cydia, and then deleting again...it just seems risky. I guess I may as well give it a try...
iSpend
Jan 11, 2008
126
Update: Didn't work :[
The path is /var/mobile/Library/Weblcips/.
iSpend
Jan 11, 2008
126
thanks a lot, I'm gonna get on it right now
iSpend
Jan 11, 2008
126
what are webclips?
some of the files say blanks, others say webclips...is it safe to delete webclips?
